inconsistency delineating watershed (contributing area) from a single point (cell)
1095
12-11-2010 10:41 AM
LindaKlein1
I am trying to delineate the upslope contributing area from any cell in a 10m dem. I am using the pour point feature with the watershed tool. From the flow accumulation raster, I know for each cell, how many other cells contribute flow. Now, I want to know where all those cells are. I create a feature class of the point (cell) I am interested in know where all the cells are that contribute to its total flow accumulation number. I then use this point (feature class) as the input, along with flow direction, in the watershed tool. The problem is that sometimes I get the correct number of cells in the output, other times I don't. And, I can't figure out why. For instance, I have a cell that has a flow accumulation value of 398. I then use the watershed tool and find the area of these 398 cells that contribute. Great. Then, I choose another cell I am interested in - say, one that has a flow accumulation value of 561 - using the same procedure that correctly identified the 398 cells - will now only show me 15 cells of the 561 that are suppose to be contributing. Why is it not showing me all 561?
Thank you,
Linda
AliWhite
Did you ever find an answer to this?
