Generating watershed in 9.3.1
1341
09-20-2010 11:12 AM
DanaRobinson
Have generated a Flow direction raster using 10 DEMs, for use in generating a watershed based on a shapefile of pour points which consist of randomly selected stream sample locations.  When generating this watershed raster I get watershed wihich seems to have vertical and horizontal delineations radiating out from the location of the pour point.   This horizontal line appears yo cutoff part of the watershed, and is located over 3 km south of hte edge of the flow direction raster.
Extent was set to default.  Moving the pour point a few meters "downslope" based on did not change the results.  I feel that it might have to do with flow direction raster, but regeneration of this did not change it either.  I have attached a screen shot.  Does anyone know how to correct this?
DanaRobinson
So sorry for typos.  Did not Preview post.
Have generated Flow Direction using 10 meter DEMs.
Moving the pour point a few meters "downslope" based on generated flow accumulation did not change the results.
Think the rest of the typos are understandable.
AliWhite
Did you ever find an answer to your problem? I'm having the same issue and have been unable to resolve it. Any help would be appreciated!
