I was running Rastor calculator but I got indentation errors
2206
02-09-2016 04:32 AM
HanibalLemma
i was trying to execute the following command in Map algebra-----raster calculator.
     Con((("tpi300m_std" > -100) & ("tpi300m_std" < 100)) & ((("tpi2010m_std" > -100) & ("tpi2010m_std" < 100)) & ("slope_deg" <= 5)),5)
     con((("tpi300m_std" > -100) & ("tpi300m_std" < 100)) & ((("tpi2010m_std" > -100) & ("tpi2010m_std" < 100)) & ("slope_deg" > 5)),6)
     con((("tpi300m_std" > -100) & ("tpi300m_std" < 100)) & ("tpi2010m_std" >= 100),7)
     con((("tpi300m_std" > -100) & ("tpi300m_std" < 100)) & ("tpi2010m_std" <= -100),4)
     con(("tpi300m_std" <= -100) & (("tpi2010m_std" > -100) & ("tpi2010m_std" < 100)),2)
     con(("tpi300m_std" >= 100) & (("tpi2010m_std" > -100) & ("tpi2010m_std" < 100)),9)
     con(("tpi300m_std" <= -100) & ("tpi2010m_std" >= 100),3)
     con(("tpi300m_std" <= -100) & ("tpi2010m_std" <= -100),1)
     con(("tpi300m_std" >= 100) & ("tpi2010m_std" >= 100),10)
     con(("tpi300m_std" >= 100) & ("tpi2010m_std" <= -100),8)
however, I got the message ERROR 000539 parsing error indentationError unexpected indent.
anybody can help me please?
JayantaPoddar
You would need to combine them in a single expression, like Nested Conditions
Con((("tpi300m_std" > -100) & ("tpi300m_std" < 100)) & ((("tpi2010m_std" > -100) & ("tpi2010m_std" < 100)) & ("slope_deg" <= 5)),5,Con((("tpi300m_std" > -100) & ("tpi300m_std" < 100)) & ((("tpi2010m_std" > -100) & ("tpi2010m_std" < 100)) & ("slope_deg" > 5)),6,Con((("tpi300m_std" > -100) & ("tpi300m_std" < 100)) & ("tpi2010m_std" >= 100),7,Con((("tpi300m_std" > -100) & ("tpi300m_std" < 100)) & ("tpi2010m_std" <= -100),4,Con(("tpi300m_std" <= -100) & (("tpi2010m_std" > -100) & ("tpi2010m_std" < 100)),2,Con(("tpi300m_std" >= 100) & (("tpi2010m_std" > -100) & ("tpi2010m_std" < 100)),9,Con(("tpi300m_std" <= -100) & ("tpi2010m_std" >= 100),3,Con(("tpi300m_std" <= -100) & ("tpi2010m_std" <= -100),1,Con(("tpi300m_std" >= 100) & ("tpi2010m_std" >= 100),10,Con(("tpi300m_std" >= 100) & ("tpi2010m_std" <= -100),8))))))))))
Think Location
JayantaPoddar
Think Location
HanibalLemma
I really appreciate. it works!
