How to delineate forest sections/patches from connected polygons or raster
1804
06-26-2018 11:14 AM
LillianCollins
I have a polygon of forested area in nature preserves in one county. The forested areas are sometimes connected by only one cell and I would like to create smaller sections/patches of forest from the large polygon while getting rid of these cells or assigning it to one of the patches created. I attached a photo and you can see where large areas are only connected by one cell. I could probably manually create these sections but I was wondering if there was a better way. Is there a way to delineate or create different patches in the polygon so there are separated sections of forest? I also have a raster layer that I could work with if there is a better way using a raster. Thanks!
DanPatterson_Retired
lots of ways... but try this first to see if it gets rid of the fiddly-bits
Shrink (by 1 or 2 cells) …
 Shrink—Help | ArcGIS Desktop
then Expand (by the same amount you used in Shrink)
 Expand—Help | ArcGIS Desktop
and if you don't like that, you should have a look at...
An overview of the Generalization toolset—Help | ArcGIS Desktop
with things like
Majority filter, boundary clean, nibble, etc etc
