Generating the difference between values in two raster datasets:
7769
04-25-2011 06:36 PM
MarkEnglish
I have two seperate raster datasets with one value per pixel, and need to calcuate the difference in an output raster.  Is there a way to perform this simple calculation using two seperate rasters.
Thanks!
TimothyHales
Esri Notable Contributor
Hi Mark,
You can find the difference using the Spatial Analyst tools.  The Minus tool will allow you to subtract one raster from the other.  There is also an assortment of other raster evaluation tools as well within the Math toolset.
-Timothy
