Focal statistics problem values
11709
14
06-20-2019 08:01 AM
RobertoFilloramo
I am using ArcGIS 10.1 and I am working with the Focal Statistics tool in order to get a smoother surface (I set "neighborhood rectangle 3x3 cell units" and as statistics type "mean"). The obtained result it looks like not so fine since the focal st. values seem increased respect to the input raster (see figures), but I don't understand the reason. The doubt arose making some comparison with other results in which the focal st. raster values are smaller than the input raster.
Could someone help me?
Thank you
DanPatterson_Retired
Time to set the raster nodata is set so it doesn't foul up the focal stats in the areas where nodata borders data
LanceCole
Dan, I agree.  Typically seeing zero (0) data is a red flag something is up unless expected.
JuanLaguna
Hi Roberto.
I'm sorry you're having some difficulty.  Let's see if we can help get this sorted out.
First off, I notice the your input raster is identified as a 64-bit double-precision TIFF.  Is this intentional?  I don't often come across this particular type of Tiff data.  If you use the Copy Raster GP tool to make a new version of the data with the Pixel Type set to a regular 32-bit float, does the resulting raster have the same outcome when used in the Focal Statistics tool?
If you convert your input raster to an Esri GRID format raster and use that as input, does the problem recur?
I did some testing with some local data that I mapped to a value range similar to what you report, but could not produce any unexpected results.  Would it be possible to provide a copy of your data to test with?  If you could prepare a smaller section of it that still demonstrates the problem, then it would facilitate the investigation.
Juan
RobertoFilloramo
thank you for your suggestion, I uploaded the sample tiff and a csv sample tile in order to have an idea on my data. The tiff is originated from the csv in CloudCompare software.
Moreover, I tried the tools that you suggested but the result is the same (see fig.)
JuanLaguna
Hi Roberto.
As others had suggested, the issue does seem to be a result of having cells with a value of 0 (instead of NoData) present in the input.
Highlighted below is a section of the input demonstrating some of those cells:
      Input with cells of value 0 identified
If you were to perform a Con operation on the input to convert those 0 values to actual NoData:
The final result should be more what you were expecting:
Hope this helps!
Cheers,
Juan
Spatial Analyst team
Esri, Inc
