Fill sink problem
3746
05-23-2017 11:54 AM
Nicolasde_la_Peña
Hello everyone,
I'm having a problem with the tool Fill sinks, when I start to running the tool, appears that error, pc memory I don't think that is the problem (16gb ram i7) and the image that I'm processing it's a .tiff.. I'm stuck on this point, could someone help me??
Thanks for the attention!
DanPatterson_Retired
that error 010067 comes up a lot under scenarios.  The suggestion begins with ensuring you are working with projected rasters and try to send the outputs to a real folder with a short path and grid compliant filename.  Try an esri grid as the destination file type, then a *.tif.  Make sure you have specified, the analysis extent and check the raster file sizes and anything else in the Environments tab of the tool in arctoolbox when you run it from there.
