Field Calculator Raising a Field To a Power
4718
08-19-2010 10:36 AM
ZacharyMetz
I'm trying to raise the value of a field to a power.  How do I go about doing this?  What is the prelogic VBA script?
I notice the first 800 values where calculated correctly before error running VBA code pops up.  using the code below
36.89*([THICKNESS]^-0.3883)  Where am I going wrong?
*Update* The formula does not work when the value of Thickness = 0  causing the user interrupt error
WilliamClark
If thickness is allowed to = 0 then you end up with 0 raised to a negative power which is an undefined number.  You may have to set some rules/parameters to disallow thickness = 0.
ZacharyMetz
What would be the correct pre-logic VB Script parameters to exclude 0?
RichardRupp
Could you first select the features with [Thickness] > 0, and then run your algorithm on the selected set?
