Failed to execute floating raster to integer raster
4646
10-28-2014 07:35 AM
hairai
currently im facing a problem in converting FLOATING RASTER to INTEGER RASTER by using "spatial analyst tools (arc toolbox) > math > Int" . However, it shows warning of "error ERROR 999998: Unexpected Error. Failed to execute (Int)." * as shown in the attached file * . i've used both raster calculator method and spatial analyst tools in arctoolbox but still failed. how to overcome this problem sir ? Thank you.
DanPatterson_Retired
esri grids should have a filename < 10 characters (IMS), contain no spaces and be housed in a folder without spaces.  It appears either the inputs or outputs don't meet these conditions.
JayantaPoddar
Define a shorter pathname of the input and output rasters (e.g. D:\Project\Raster). Don't keep them in folders like My Document. Let us know if the issue still persists
Think Location
