Dividing an integer raster by an integer raster
969
10-29-2010 06:47 AM
BruceWiggins
Hi-
Why does dividing an integer raster by an integer raster (either in the Raster Calculator or the Divide tool) produce an output integer raster, instead of a floating-point raster?
DanPatterson_Retired
It is referred to as integer division and is common in most programming languages, also, it is described in the help files.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z0000008r000000.htm
BruceWiggins
OK, thanks.  I'm not a programmer, so I expected a "normal" math result.  Other tools involving division (Cell Statistics (mean), for example) produce floating point output, so I assumed that division would too.
I suspect that cell statistics (mean) enforces floating point division to avoid what you have observed
