Cellular Automata with ArcGIS or ERDAS?
5555
02-08-2013 12:54 AM
MOHAMMEDHABBOUB
Hello everybody,
Does anybody know how could I use Cellular Automata with ArcGIS or ERDAS? or at least has a tutorial about Cellular Automata?
Habboub
JamalNUMAN
Legendary Contributor
Hello everybody,
Habboub
Hi MOHAMMED,
Please access the link below which has similar discussion
https://forums.clarklabs.org/entries/21816678
Also access the link below to download a pdf file that shows the method of prediction of land use in 1999 based on the raster of land use of two previous years: in 1971 and 1985
http://www.mediafire.com/view/?z2j6buscs83433z
Hope this helps,
Best
Jamal
Jamal Numan
JamalNUMAN
Hello everybody,
Habboub
Hi MOHAMMED,
Hope this helps,
Best
Jamal
Jamal Numan
MOHAMMEDHABBOUB
Thanks Jamal,
This seems very helpful.. I'll start hitting the books and see if I need further help
Thanks again.
Habboub
JamalNUMAN
Thanks Jamal,
Thanks again.
Habboub
Yes. Just try to follow the example in the pdf file to catch the idea. You can download its data from the internet.
Good luck
Best
Jamal
Jamal Numan
AndresOrlando
Hi Jamal,
I was looking for a tool or extension to use with ArcGis for celullar automata. I found your post, but one link is not available , specifically the one with the pdf. Can you send me the file or other link?
Thank you very much for your time.
JamalNUMAN
Please refer to the link below to download pdf\data
http://www.mediafire.com/download/ls2kra2ki6tbhrp/IDRISI_Selva_Tutorial_Manual_Version_17_January_20...
Jamal Numan
