Attribute Rule to Update a Field based on edit to another Field
3905
04-23-2021 01:28 PM
by Anonymous User
Not applicable
Hello,
I am new to arcade expressions and I am attempting to make a new attribute rule for a Stream polyline feature class. My goal is to track when a features name has changed. Where, if the Stream Name field (Str_Name) is updated, then another field (NameChange) within the same feature class table is updated to say Yes.
I have looked at some other resources and think that I am close, but I keep getting "False" instead of Yes or No.
Here is a snip of the attribute rule. I am using an Immediate Calculation Rule.
Any help would be appreciated.
Thanks!
2 Solutions
by Anonymous User
Not applicable
I was. I have since figured it out after messing around. Using some logic and Return and a string.
Thanks!
by Anonymous User
Not applicable
 Sure, no problem
JoeBorgione
Are you basing your expression on this post from  @HusseinNasser2 ?
That should just about do it....
by Anonymous User
Not applicable
Thanks!
JoeBorgione
care to share?
by Anonymous User
Not applicable
 Sure, no problem
JoeBorgione
Simple and elegant!  I've never had occasion to use the $orginalfeature global, but it looks like it can be very helpful.
