Tree Management Solution
1823
06-10-2022 12:00 PM
RachaelMurtaugh
Will the tree management solution track maintenance history and site history. For example: If we have a potential planting site, then it's planted, then trimmed, watered, etc. Will that history be saved in the solution's tree layer. Does archiving need enabled? How do you then view the history of that location?
2 Solutions
ChrisFox
@RachaelMurtaugh, yes it will. Maintenance history is written to a related table on the planting space/tree. You can view the history using the Tree Management Center included in the solution by selecting a planting space/tree and viewing the maintenance history table.
mdagle
Hi Rachael - The Trees feature layer included with the Solution has a related maintenance table where activities like planting, watering, and trimming can be tracked. The history can be viewed using the Tree Management Center. Tree features themselves can be collected as available planting spaces, planted trees, retired spaces, or stumps to correspond to the the space's lifecycle.
I hope that helps!
Mike
ChrisFox
mdagle
I hope that helps!
Mike
