Moving a map to a new computer
2895
07-23-2011 05:50 PM
NathanBickle
Hello, if anyone could help me it would be greatly appreciated.  I am about to receive a new computer at work.  I use BA with seed points and a zip code layer to create a map for recruiting zones for the entire US.  I have been told that I cannot move an editable from one computer to another.  I can export the map and move it, but once that has been done, I cannot make changes.
If anyone out there can assist me in moving an editable map from one computer to another, it would be greatly appreciated.
Jason_RobinsonRobinson
As for Business Analyst generated data which is located in the My Output Data folder all one would need to do is make a backup/copy of it on the current computer and then once Business Analyst is installed on the new computer simply re-name the new My Output Data folder and copy/paste the older My Output Data folder to the new computer.
Now if there is other data in a specific map document that was manually added/created and is stored elsewhere you will need to copy it to the same locations on the new computer or reconnect the data.
