Failed to create Service - Local Gov Solutions
839
09-29-2020 03:44 PM
RickeyFight
MVP Alum
I used ArcGIS pro to create the Code Violation | ArcGIS Solutions for Local Government on my Enterprise Portal.
When I deployed it everything worked as expected. I did some configuring of the solution.
I am not exactly sure how I broke the layer but I did. So I deleted everything that was created in the attempt to start over and re deploy the solution.
Now when I go to deploy the solution I keep getting the same error.
Failed to create Feature Service LandUseViolatiosn: Error: Relationship class with the same name does exist.
(Error Code: 500)
 Failed to add Code Violation.
Any suggestions how to fully delete the Relationship class? Or to bypass the error. I tried using a different account and in a different folder. I still get the same error.
I have tried this :https://community.esri.com/thread/238191-how-to-deploy-a-solution-that-has-already-been-used
Thanks!
