How to deploy a solution that has already been used
1545
08-06-2019 01:15 PM
AllisonWilliamson
Good Afternoon,  I'm trying to deploy the Capital Project Dashboard using the Solution Deployment Tool in ArcPro (2.4).  Every time we try to deploy, the green check mark is already in place due to the solution being used by someone else in our organization for another Capital Project Dashboard.  How can we re-deploy?  We have tried pushing it to a different folder in the organization, but no data is created, and when we click on the green check mark, it links us to the other dashboard that was previously made.  See below:
AndyShoemaker
Hi Allison,
You can deploy a new copy of a solution by changing the settings of the deployment.
In the Top right corner, the three parallel lines (looks a bit like a hamburger) is a drop down where you can change the settings. If you uncheck "Use Existing Items in the Organization", it will redeploy everything for you.
If you then need to use some of the existing services (reference layers or other data), you can then just switch them in on the webmap.
Andy Shoemaker
AndyShoemaker
Hi Allison,
Andy Shoemaker
AllisonWilliamson
Thank you! That did it.
