When displaying the Streetlight Management Dashboard, the Streetlights Viewer Web Map is shown, which uses the TrafficControlDevices_view feature layer is displayed.
I added fields to TrafficControlDevices, but they are not visible in TrafficControlDevices_view, so I cannot add them to the Web Map popup.
How can I edit the TrafficControlDevices_view feature layer to configure the Streetlights Viewer popup?
Hi Hans,
In order for new fields to show up in the view you need to update the view definition. This can be found on the settings tab under the Feature layer (hosted, view) section
These fields should now be available in the the map popups.
More comprehensive information on setting view definitions can be found here if your interested:
https://doc.arcgis.com/en/arcgis-online/manage-data/set-view-definition.htm
Hi Hans,
