Edit "_view" feature layer in Streetlight Management
1355
07-09-2024 02:36 PM
Hans_I-4
When displaying the Streetlight Management Dashboard, the Streetlights Viewer Web Map is shown, which uses the TrafficControlDevices_view feature layer is displayed.
I added fields to TrafficControlDevices, but they are not visible in TrafficControlDevices_view, so I cannot add them to the Web Map popup.
How can I edit the TrafficControlDevices_view feature layer to configure the Streetlights Viewer popup?
Andrew_Eaton
Hi Hans,
In order for new fields to show up in the view you need to update the view definition.  This can be found on the settings tab under the Feature layer (hosted, view) section
  1. Click the update view button
  2. Click Next
  3. Navigate to the Streetlights layer and select it (you should see a fields section)
  4. Expand the fields and press the Select Fields button.  (You should see your new fields in this list)
  5. Ensure any of your new fields are checked off and then update the entire view.
These fields should now be available in the the map popups.
More comprehensive information on setting view definitions can be found here if your interested:
https://doc.arcgis.com/en/arcgis-online/manage-data/set-view-definition.htm
Andrew_Eaton
Hi Hans,
  2. Click Next
Hans_I-4
Thanks!
