Cemetery Solution - Sections overwritten by Blocks and vice versa
1786
08-21-2023 03:34 PM
Henry
Hi there,
I've deployed the Cemetery Solution and have been appending data and have run into a weird issue while creating and appending data for the layers.
Going through the tasks, I created Sections, and then since our cemetery has Blocks, I would run the append tool as illustrated by the task. However, even though I was pointing to the correct Layer (the Sections layer inside the Cemeteries Hosted Feature Layer) data that was meant to append to Blocks shows in Sections instead. When I go to append to Sections, that data shows up in Blocks.
Is this by design? Am I missing something with how this Solution was set up or have others encountered this as well?
Thank you
Henry
DanielWickens
Hi @Henry
I am not aware of this behavior in the Cemetery Data Management pro project. When running the data loading tasks, make sure the Target Dataset is set to the boundary layer that corresponds to the input boundary data you're loading (screenshot below). That should clear up any issues with data being loaded into the wrong layers.
