AGOL GIS Request Management Solution: Displaying CSV "Label" Instead of "Name" in Dashboard Filters and Tables
2157
5
08-13-2024 11:36 AM
Cierra_Scriven
Hello again @BrandiRank22  & @DanielWickens ,
I am currently working on the AGOL GIS Request Management Solution and have encountered an issue I could use some help with. I've set up the CSV that feeds the Survey123 form to include pre-made values for the "assignedto" field, as per the documentation. Specifically, the "name" field in the CSV contains the team member's email address (e.g., [email protected]), and the "Label" field contains their full name (e.g., Jane Doe).
However, in the dashboard, I would prefer to see the label "Jane Doe" displayed in the sidebar filters and table column values. Instead, the dashboard is showing the email address (e.g., [email protected]) in these areas.
Could you provide guidance on how to configure the dashboard so that the label (e.g., "Jane Doe") is shown instead of the email address? Any advice or examples would be greatly appreciated.
Thank you in advance for your help!
Cierra_Scriven
Surprise! I actually managed to solve by modifying the Arcade script in the Dashboard Configuration -> Table -> Values.
There are two lines (19 and 20 at the time of writing this post) that contain variables:
var urgent_textcolor = IIf($datapoint.urgent == "Yes", '#ffffff', '')
var urgent_bgcolor = IIf($datapoint.urgent == "Yes", '#a11506', '')
Just below them on line 21 through 25 I added another variable:
var name_assigned = IIf($datapoint.assignedto == "[email protected]", 'Jane Doe',
IIf($datapoint.assignedto == "[email protected]", 'John Doe', ''))
Then I replaced the "displayText" for a column return like so:
assignedto: {
displayText : name_assigned,
textColor: '',
backgroundColor: '',
textAlign: 'left',
iconName: '',
iconAlign: '',
iconColor: '',
iconOutlineColor: ''
Success!
BrandiRank22
Hi @Cierra_Scriven ,
For the filters in a dashboard, go to that filter and under "selector" scroll down and click "Load categories".  You will see their email in the "category" listing and you can change the "Label"
BrandiRank22_0-1723574905565.pngBrandiRank22_0-1723574905565.pngBrandiRank22_1-1723574937165.pngBrandiRank22_1-1723574937165.png
Cierra_Scriven
assignedto: {
textColor: '',
textAlign: 'left',
iconName: '',
iconAlign: '',
iconColor: '',
Success!
Kara_Shindle
Hi @CierraScriven , can you elaborate on where you can find "Dashboard Configuration -> Table -> Values."  Is this an enterprise direction or an AGOL one?  Is this on a specific dashboard?
DanielWickens
@Kara_Shindle - Cierra is referring to the Values -> Advanced formatting section of the Table element configuration options. This is the case in both ArcGIS Online and ArcGIS Enterprise.
LaurenAlt
Hi Cierra,
I did it slightly another way. I just split the end of the email address off, so our dashboard has first.last as the assigned to label...
In the Value options - Advanced formatting
var email = $datapoint.assignedto;
var username = split(email,"@")[0];
then
assignedto: {
      displayText : username,
      textColor: '',
      textAlign: 'left',
      iconName: '',
      iconAlign: '',
      iconColor: '',
Happy days 😊
