Extend Damage Assessment Reports
687
03-29-2022 06:41 AM
JeremiahLindemann
The ArcGIS Solution for Damage Assessment includes reporting capabilities, along with dashboards and other tools for monitoring progress of assessments.  After conducting Damage Assessments,  a typical request is to see the results in a form of a report.  Some folks utilize the FEMA Street Sheet reports or other resources provided by FEMA which the existing report included in the solution is based off of.
Another common request has been to further categorize these reports.  For instance, utilize a street sheet style report to summarize all properties summarized by county.  With the recent update of Survey123, report templates now allow for the where clause to be composed dynamically based upon other attributes.  Below is an example output that summarizes attributes from damage assessments based upon counties the assessment was conducted in.
You can use this word doc is an example template that utilizes the schema from the ArcGIS Solution for Damage Assessment that you can use to generate a similar report. You can extend this template by adding your logo, adding additional attributes and text as needed.
