zoom to feature
4121
09-14-2020 11:40 AM
AlexRodriguez
Javascript API v4.16
Building a page that opens up a map and zooms to the extent of the feature ID passed to it from the previous page.
So far:
1.  the feature ID is set in the "localStorage" of page 1
2.  in Page 2 I retrieve that value and attempt to zoom to that feature.
3.  I have a function that will do the zooming but I can't get it to work.
4.  Here is the function:
 function zoomToPassedFeature(strLocationCode){
   // Create a QUERY for a feature layer in the map
   const layQLayer = new FeatureLayer({
     url: strMapServiceURL + "/FeatureServer/3" // Yards layer
   const query = new Query();
   query.where = "LocationCode = '" + strLocationCode + "'";
   layYards.queryExtent(query).then(function(results){
     view.goTo(results.extent);  // go to the extent of the results satisfying the query
   a.  if I put that function within the REQUIRE code block I get:  ReferenceError: Query is not defined
   b.  if I put that function outside the REQUIRE code block I get:  "zoomToFeatureExtent()" no defined.
How am I supposed to be doing this?
thanks!
Tags (1)
KenBuja
MVP Esteemed Contributor
What does your require section look like? Are the function arguments in the same order as the modules?
AlexRodriguez
I finally figured it out.  The KEY being the first line in the section at the bottom:
 view.whenLayerView(layYards).then(function(layerView){...
The "whenLayerView" listener on the "view".
So now when I pass that FeatureID value and this layer is loaded it begins the process of querying and zooming.
Require Statement:
require([
  "esri/Map",
  "esri/views/MapView",
  "esri/layers/FeatureLayer",
  "esri/widgets/LayerList",
  "esri/widgets/Legend",
  "esri/widgets/Search",
  "esri/tasks/Locator",
  "esri/renderers/UniqueValueRenderer",
  "esri/widgets/Expand",
  "esri/tasks/IdentifyTask",
  "esri/tasks/support/IdentifyParameters"
  function(
    Map
    MapView,
    FeatureLayer,
    LayerList,
    Legend,
    Search,
    Locator,
    UniqueValueRenderer,
    Expand,
    IdentifyTask
    IdentifyParameters
// and the end of the JS file looks like:
  // Zoom to the feature ID passed from the AnL Site
      var query = layYards.createQuery();
        view.goTo(results.extent);  // go to the extent of all the graphics in the layer view
}); // End of REQUIRE
