Error "Unable to get property _getInfo" in one Service Name.
1792
02-20-2018 11:44 PM
EsperanzaBravo_Igual
I publish a new service name with AGServer 10.5 without problems, but I run my program I have an error "Unable to get property _getInfo" in this Service Name.
I can't get access to show visibility of layers in the New Service.
I have more services Name and I dónt have problems.
I use Api Javscript 3.23.
Can I hel me?
Thanks you
This service Name is a ArcGISDynamicServiceLayer, but i not choose to cache it.
Then, i repair it, i desintalled/installed AGS and it solved.
Thanks a lot!!!
RobertScheitlin__GISP
What type of service is this?
What does your code look like that is trying to consume this service?
In Manager, I publishes this new service with capabilities WMS. This service has several layer with only vectors no rasters.
I use Api Javascript and I can´t show in the map it. My web application have more services (they published with the same way as this) without problems.
I can´t know if it have any relation with update  to AGServer 10.5 or other problem,
Thanks you
More specifically.
So you publish a standard Map Service with WMS capability checked? Did you choose to cache this service?
In your code you are adding it as a ArcGISDynamicMapServiceLayer?
Thanks a lot!!!
