Circle becomes an ellipsis. Can I create a perfect circle? 4.x
1192
06-05-2017 03:34 PM
JasonBaddley
I have an app that allows the user to draw a circle on the map (using my own svg layer above the ESRI map). When they are done, I convert the user's inputs into an ESRI Circle. It almost works. The problem is that if I use nautical-miles I always get an ellipsis that is taller than it is wide. The user is then confused about why their circle doesn't match their input.
Any suggestions for either forcing a true circle while still using nautical-miles or a better way of allowing a user to draw a circle?
