I need to create tile packages using my own scales, in the early beta version I could do it directly from the 'Share As' 'Tile Package' menu item. Currently I can only use predefined values, which would be fine if I could modify both the 'highest level of detail' and the 'lowest level of detail'. However using a very simple map document (1 layer) and 1 scale value, it works.
I've also tried using a tiling scheme file (ArcToolbox - Generate MapServer Cache Tiling Scheme), again using my simple document and 1 scale value. That generates no errors. However, when I use the xml file as the Tiling Scheme, Analyze gives no errors, but as soon as I say share, I get a pop-up, that says 'Invalid function arguments'.
Finally I tried ArcToolbox - Create Map Tile Package, using all the same parameters. It gives me an Error 999999 : Error executing function.
Am I doing something wrong?
Andrew Purkis
