Problem Creating Tile Packages
3866
08-22-2012 05:57 AM
AndrewPurkis
I need to create tile packages using my own scales, in the early beta version I could do it directly from the 'Share As' 'Tile Package' menu item. Currently I can only use predefined values, which would be fine if I could modify both the 'highest level of detail' and the 'lowest level of detail'.  However using a very simple map document (1 layer) and 1 scale value, it works.
I've also tried using a tiling scheme file (ArcToolbox - Generate MapServer Cache Tiling Scheme), again using my simple document and 1 scale value. That generates no errors. However, when I use the xml file as the Tiling Scheme, Analyze gives no errors, but as soon as I say share, I get a pop-up, that says 'Invalid function arguments'.
Finally I tried ArcToolbox - Create Map Tile Package, using all the same parameters. It gives me an Error 999999 : Error executing function.
Am I doing something wrong?
Andrew Purkis
MichaelBranscomb
Esri Frequent Contributor
I think your best option for tackling this would be to contact technical support.
Cheers
Mike
CaseyBentz
Andrew Purkis
Andrew, I am having this same problem.  Did you figure out how to solve this?
AndrewPurkis
The customer's data that I was using contained a mixture of projection types. Some were defined with a NAD of Feet and some of type Feet_Intl.  Not that I guessed that from Error Code 999999, thankfully technical support found it!
Hope that helps!
Andrew Purkis
