Dear Gurus!
I am finding the best practice to solve next tasks.
1. Show in popup window some image. Image is in file, attached in some way to the feature . In my case image files attached to records of x,y-table.
2. Show in popup window list of attribute values.
Pop-up window should appear at onmouseover event.
May be some reference to accelerate the process.
Thanks in advance!
I read http://help.arcgis.com/en/webapi/wpf/help/index.html#/Adding_MapTips/01n70000001z000000/ , but there are a lot of x,y-tables. It is desirable to look at the example of a realization MapTips in code.
P.S. I will try to see https://community.esri.com/thread/14745
Yes, last reference solved the problem. My xaml :
<UserControl x:Class="MapModule.Views.MapView"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:esri="http://schemas.esri.com/arcgis/client/2009"
<Grid
<esri:Map x:Name="Map" Background="White" WrapAround="true"
Extent="6095000,6810000,6900000,7258000" >
<esri:ArcGISDynamicMapServiceLayer ID="BaseLayer"
Url="http://localhost:6080/ArcGIS/rest/services/streetRK/MapServer" />
<esri:FeatureLayer ID="routes_osm"
Url="http://localhost:6080/ArcGIS/rest/services/streetRK/MapServer/1">
</esri:FeatureLayer>
</esri:Map>
</Grid>
</UserControl>
And in code behind (similarly, it is possible to make in viewModel 😞
FeatureLayer featureLayer = Map.Layers["routes_osm"] as FeatureLayer;
featureLayer.MapTip = new LegendView();
Thank you dbroux-esristaff again!!! Problem solved.
One more refinement.
When constructing MapTip view I need to know the feature over which the mouse is. How it can be found ? Is there are some field In feature layer which consist the value of current feature under mouse or it must be determined in MouseEnter event?
Next variant suit me:
In xaml :
<esri:FeatureLayer ID="bridges"
Url="http://localhost:6080/ArcGIS/rest/services/streetRK/MapServer/2"
MouseEnter="FeatureLayer_MouseEnter" >
In MapView.xaml.cs constructor I initialize MapTip:
FeatureLayer featureLayer = Map.Layers["bridges"] as FeatureLayer;
bridgeView = new BridgeView();
featureLayer.MapTip = bridgeView;
And in the MouseEnter event handler :
private void FeatureLayer_MouseEnter(object sender, GraphicMouseEventArgs e)
bridgeView.km.Text = e.Graphic.Attributes["km"].ToString();
// And so on for other attributes, which used in MapTip PopUp View
Hi Anatolii,
This SDK sample might interest you: ArcGIS API for Silverlight - Interactive Samples | ArcGIS for Developers There is no need to subscribe to MouseEnter to get to the feature whose attributes will be displayed. Notice this sample has no code-behind but let me highlight the following code.
<esri:FeatureLayer.MapTip> <Border CornerRadius="10" BorderBrush="#FF222957" BorderThickness="3" Margin="0,0,15,15"> <Border.Background> <LinearGradientBrush EndPoint="1.038,1.136" StartPoint="0.015,0.188"> <GradientStop Color="#FFD1DFF2"/> <GradientStop Color="#FF0088FF" Offset="0.946"/> </LinearGradientBrush> </Border.Background> <Border.Effect> <DropShadowEffect ShadowDepth="10" BlurRadius="14" Direction="300" /> </Border.Effect> <StackPanel Margin="7"> <TextBlock Text="{Binding [CITY_NAME]}" FontWeight="Bold" Foreground="Black" /> <StackPanel Orientation="Horizontal"> <TextBlock Text="Population: " Foreground="Black" /> <TextBlock Text="{Binding [POP1990]}" Foreground="Black" /> </StackPanel> </StackPanel> </Border> </esri:FeatureLayer.MapTip> </esri:FeatureLayer>
MapTip can be constructed with any UIElement, its content can also be bound to an attribute. These bindings will resolve itself when your mouse enters a feature. {Binding [CITY_NAME]} assumes that CITY_NAME is a requested OutField.
Thank you very much, Jennifer!
I chose a different path, as I had to show my own form with parameters, Images, etc. In xaml :
<esri:Map x:Name="Map" Background="White" WrapAround="true" Extent="6095000,6810000,6900000,7258000" MouseMove="Map_MouseMove" MouseClick="Map_MouseClick"> <esri:ArcGISDynamicMapServiceLayer ID="BaseLayer" Url="http://localhost:6080/ArcGIS/rest/services/streetRK/MapServer" /> <esri:FeatureLayer ID="bridges" Url="http://localhost:6080/ArcGIS/rest/services/streetRK/MapServer/2" MouseEnter="FeatureLayer_MouseEnter" > </esri:FeatureLayer> </esri:Map> </esri:Map>
In constructor of code behind:
bridgeView = new BridgeView(); featureLayer.MapTip = bridgeView;
And
private void FeatureLayer_MouseEnter(object sender, GraphicMouseEventArgs e) { try { bridgeView.km.Text = e.Graphic.Attributes["km"].ToString(); //processing other attributes to form the view } catch (Exception){} }
