Popup window when onmouseover event
4605
11-10-2014 03:48 AM
AnatoliiTerentiev
Dear Gurus!
I am finding the best practice to solve next tasks.
1. Show in popup window some image. Image is in file,  attached   in some way to the feature .  In my case image files attached to records of x,y-table.
2. Show in popup window list of attribute values.
Pop-up window should appear at onmouseover event.
May be some reference to accelerate the process.
Thanks in advance!
AnatoliiTerentiev
I read http://help.arcgis.com/en/webapi/wpf/help/index.html#/Adding_MapTips/01n70000001z000000/   , but there are a lot of x,y-tables.  It is desirable to look at the example of a realization MapTips in code.
P.S. I will try to see https://community.esri.com/thread/14745
Yes, last reference solved the problem. My xaml :
<UserControl x:Class="MapModule.Views.MapView"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             xmlns:esri="http://schemas.esri.com/arcgis/client/2009"
    <Grid
        <esri:Map x:Name="Map" Background="White" WrapAround="true"
                                Extent="6095000,6810000,6900000,7258000" >
            <esri:ArcGISDynamicMapServiceLayer ID="BaseLayer"
                            Url="http://localhost:6080/ArcGIS/rest/services/streetRK/MapServer" />
            <esri:FeatureLayer   ID="routes_osm"
                            Url="http://localhost:6080/ArcGIS/rest/services/streetRK/MapServer/1">
            </esri:FeatureLayer>
       </esri:Map>
    </Grid>
</UserControl>
And in code behind (similarly, it is possible to make in viewModel 😞
            FeatureLayer featureLayer = Map.Layers["routes_osm"] as FeatureLayer;
            featureLayer.MapTip = new LegendView();
Thank you dbroux-esristaff‌ again!!! Problem solved.
AnatoliiTerentiev
One more refinement.
When constructing MapTip view I need to know the feature over which the mouse is. How it can be found ? Is there are some field In  feature layer which consist  the value of current feature under mouse or  it must be determined in  MouseEnter event?
AnatoliiTerentiev
Next  variant suit me:
In xaml :
<esri:FeatureLayer    ID="bridges"
      Url="http://localhost:6080/ArcGIS/rest/services/streetRK/MapServer/2"
         MouseEnter="FeatureLayer_MouseEnter" >
In MapView.xaml.cs constructor I initialize MapTip:
            FeatureLayer featureLayer = Map.Layers["bridges"] as FeatureLayer;
            bridgeView = new BridgeView();
            featureLayer.MapTip = bridgeView;
And in the MouseEnter event handler :
private void FeatureLayer_MouseEnter(object sender, GraphicMouseEventArgs e)
      bridgeView.km.Text = e.Graphic.Attributes["km"].ToString();
      // And so on for other attributes, which used in MapTip PopUp View
JenniferNery
Hi Anatolii,
This SDK sample might interest you: ArcGIS API for Silverlight - Interactive Samples | ArcGIS for Developers  There is no need to subscribe to MouseEnter to get to the feature whose attributes will be displayed. Notice this sample has no code-behind but let me highlight the following code.
                    <esri:FeatureLayer.MapTip>
                        <Border CornerRadius="10" BorderBrush="#FF222957" BorderThickness="3" Margin="0,0,15,15">
                            <Border.Background>
                                <LinearGradientBrush EndPoint="1.038,1.136" StartPoint="0.015,0.188">
                                    <GradientStop Color="#FFD1DFF2"/>
                                    <GradientStop Color="#FF0088FF" Offset="0.946"/>
                                </LinearGradientBrush>
                            </Border.Background>
                            <Border.Effect>
                                <DropShadowEffect ShadowDepth="10" BlurRadius="14" Direction="300" />
                            </Border.Effect>
                            <StackPanel Margin="7">
                                <TextBlock Text="{Binding [CITY_NAME]}" FontWeight="Bold" Foreground="Black"  />
                                <StackPanel Orientation="Horizontal">
                                    <TextBlock Text="Population: " Foreground="Black" />
                                    <TextBlock Text="{Binding [POP1990]}" Foreground="Black" />
                                </StackPanel>
                            </StackPanel>
                        </Border>
                    </esri:FeatureLayer.MapTip>
MapTip can be constructed with any UIElement, its content can also be bound to an attribute. These bindings will resolve itself when your mouse enters a feature. {Binding [CITY_NAME]} assumes that CITY_NAME is a requested OutField.
AnatoliiTerentiev
Thank you very much, Jennifer!
I chose a different path, as I had to show my own form with parameters, Images, etc. In xaml :
                                Extent="6095000,6810000,6900000,7258000" MouseMove="Map_MouseMove" MouseClick="Map_MouseClick">
       </esri:Map>
        </esri:Map>
In constructor of code behind:
And
            try
                       //processing other attributes to form  the view
            catch (Exception){}
