Connecting to Garmin USB GPS from code
1548
08-16-2012 12:36 PM
sirishapolsapalli
I am trying to get my current location using a Garmin GPS 18 X USD device using the code from the samples provided with ArcGIS Runtime SDK for WPF. But the sample using the SerialPortGpsCoordinateWatcher. I do not have a serial port on my laptop and using the USB to Serial adaptor would not work in our situation.
How do I read the values output by the GPS with the USB adaptor using ArcGIS Runtime SDK for WPF.
Your help is appreciated.
Thank you,
Sirisha.
ShaunWeston
Yeah it seems you either need a GPS connected through the COM port or by using the Microsoft location API. If you've got a GPS connected through the USB then you'd probably have to look into writing your own code/module in WPF.NET to read in those values then basically converting them to points on a map.
BrianLocke
I have went here
[HTML]http://wb9coy.com/Projects.html[/HTML]
Great great job by WB9COY
Saved my life, I just reference the project and then made my own view model... able to get a usb puck reading but would like to actually pass the $GPPGA Sentence over to the GPS Layer instead of creating a List<Graphic> or an ObservableCollection by parsing things out. Would like to take advantage of the GpsLayer properties/methods
