set opacity of polygons independant of each other
3541
01-26-2012 11:42 AM
SteveSouthwick
Hello,
Hopefully one last question. I've got my kml file to load, and I can set the color based on an attibute, but here's my problem...When my KML file is loaded, all of the polygons are filled white.  I can lessen it by setting the whole kml layer opacity to .5, but once the color is applied, the remaning countries are filled with white.  A workaround I came up with is:
        Dim theKmlLayer As ESRI.ArcGIS.Client.Toolkit.DataSources.KmlLayer = CType(Map1.Layers("MyGraphicsLayer"), KmlLayer)
        Dim fillsymbolcolor As New SimpleFillSymbol
        Dim fillsymbolclear As New SimpleFillSymbol
        fillsymbolcolor.Fill = New SolidColorBrush(Color.FromRgb(255, 0, 0))
        fillsymbolclear.Fill = New SolidColorBrush(Color.FromArgb(0, 0, 0, 0))
            theKmlLayer.Opacity = 0.5
            For Each kl As GraphicsLayer In theKmlLayer
                For Each g As Graphic In kl.Graphics
                    If CStr(g.Attributes("name")) = "United States" Then
                        g.Symbol = fillsymbolcolor
                    Else
                    g.Symbol = fillsymbolclear
                    End If
but surely there's a way to have the kml file itself come in w/ clear polygons.  If anyone is interested, my kml file is attached.  Ideally, I'd like to KML file to load w/ the polygons not being filled rather than having to loop through every one and apply a clear fill to it.
Thanks in advance!
JenniferNery
I'm not sure how you want to select your graphic, for simplicity, I've selected just the first graphic from this SDK sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#KmlLayerSimple
Dim l = TryCast(MyMap.Layers("KmlLayer"), KmlLayer)
Dim g = l.Graphics.FirstOrDefault()
Dim s = TryCast(g.Symbol, SimpleFillSymbol)
s.Fill.Opacity -= 0.3
SteveSouthwick
Thanks for the nudge Jennifer, I'll give it a whirl today and post back if I have any questions.
SteveSouthwick
Hello Jennifer,
The code you posted doesn't seem to do anything (at least it doesn't in the way I implemented it):
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.Windows.RoutedEventArgs) Handles Button1.Click
                    End If
        Dim l = TryCast(Map1.Layers("MyGraphicsLayer"), KmlLayer)
        Dim f = l.Graphics.FirstOrDefault
        Dim s = TryCast(f.Symbol, SimpleFillSymbol)
        s.Fill.Opacity = 0.3
    End Sub
and my xmal:
<Window x:Class="MainWindow"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    Title="MainWindow" Height="350" Width="525" xmlns:esri="http://schemas.esri.com/arcgis/client/2009">
    <Grid>
        <esri:Map Background="White"  Name="Map1" WrapAround="True">
            <esri:Map.Layers>
                <esri:LayerCollection>
                    <esri:ArcGISTiledMapServiceLayer Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" />
                    <esri:KmlLayer ID="MyGraphicsLayer" Url="C:\junk\SiteMap5.Kml" VisibleLayers="Polygons"/>
                </esri:LayerCollection>
            </esri:Map.Layers>
        </esri:Map>
        <Button Content="Button" Height="23" HorizontalAlignment="Left" Margin="12,145,0,0" Name="Button1" VerticalAlignment="Top" Width="75" />
    </Grid>
</Window>
The shapes still have a solid white or red fill (depending on if the shapename is "United States" or not).  Do all imported kml files have a default fill of white?
Any other thoughts or feedback is greatly appreciated.
Thanks!
SteveSouthwick
ok.  Sorry to clog up the forums.  Seems the problem was with my kml and esri not liking how I defined my style(s):
<name>Countries</name>
<Style id="Clear">
   <LineStyle>
      <color>00ffffff</color>
      <width>2</width>
   </LineStyle>
   <PolyStyle>
      <colorMode>random</colorMode>
   </PolyStyle>
</Style>
<Placemark>
<name>Canada</name>
<styleUrl>
   #Clear
</styleUrl>
<MultiGeometry>
</MultiGeometry>
Returns a white-filled polygon.  This on the otherhand:
<Placemark>
<name>Canada</name>
<Style>
   <PolyStyle>
   </PolyStyle>
   <LineStyle>
      <width>1</width>
   </LineStyle>
</Style>
<MultiGeometry>
</MultiGeometry>
Returns a clear polygon, which is what I was looking for.  Looks like I've got some reformatting to do....
