Removing selection mode will stay for one more selection
1753
03-15-2013 01:44 PM
GeorgeFaraj
I have a toolbar item that sets selection mode to Rectangle, and another toolbar item that clears the current selection. When it clears the current selection, I want it to stop allowing me to select, until I press the former toolbar item again.
So I have this code:
private void selectTool_Click(object sender, RoutedEventArgs e)
 if (MapEditor.Select.CanExecute("Keyboard"))
  MapEditor.SelectionMode = DrawMode.Rectangle;
  //MapEditor.Select.Execute("Keyboard");
private void unselectTool_Click(object sender, RoutedEventArgs e)
 if (MapEditor.ClearSelection.CanExecute(null))
  MapEditor.ClearSelection.Execute(null);
  //MapEditor.SelectionMode = DrawMode.None;
 if (MapEditor.CancelActive.CanExecute(null))
  MapEditor.CancelActive.Execute(null);
The unselect tool correctly unselects everything, but still allows me to use my mouse to select one more time. When I release the mouse click, I am now in pan-mode.
Any ideas?
KerrieScholefield
You could use try using Button Command and CommandParameter properties. Once the selection has been removed you can not select again until you click the SelectTool button. This is also demonstrated in the Selecting a FeatureLayer sample.
http://resources.arcgis.com/en/help/runtime-wpf/samples/index.html#/Selecting_a_FeatureLayer/02q2000...
Below is a code snippet of the ToolBar Buttons with the CommandParameter and Command set in .xaml
<ToolBarTray Margin="0,0,0,267" DataContext="{StaticResource MyEditor}">
            <ToolBar>
                <Button Content="SelectTool" Foreground="Black" CommandParameter="Add" Command="{Binding Select}" />
                <Button Content="UnSelectTool" Foreground="Black" CommandParameter="Remove" Command="{Binding Select}" />
            </ToolBar>
        </ToolBarTray>
Cheers,
Kerrie
teamIgal
I encounter the same problem.
I activate the Select command using code like CCPoston does.
The Button sample provided does not help.
Why doesn't the CancelActive command work?
Is there any way to cancel the Selection command once invoked?
Thanks!
GeorgeFaraj
Cheers,
Kerrie
Hi Kerrie,
I'm actually using the commands in my toolbar items already. I'm not saying that the button is left enabled, I'm saying that when I click the map after canceling the selection, instead of panning, it allows me to select one more time. After that one time, when I click the map, I'm in pan mode.
Thanks.
teamIgal
Is there any solution to this problem?
Thanks!
JoanRickard
 I am running into this problem today.  I select in the table and then select using the tool on the map and it unselects my feature.
