Local Data Exception
4183
10
09-06-2011 02:31 AM
KarimIbrahim
I get following Exception when trying to load a "LocalArcGISDynamicMapServiceLayer"
LocalServerException was unhandled: "Failed to create service mymap MapServer. Error while setting up SOC. Error code: 500"
I have mpk that contains just some layers it works fine on other computer but on my notebool i get this error when trying to initialize local layers. Same solution works fine on three other machinces.
<esri:LocalArcGISDynamicMapServiceLayer Path="C:\Users\k.ibrahim\Documents\ArcGIS\Packages\MyMap.mpk" x:Name="_localDynamicMapServiceLayer"/>
MichaelBranscomb
Esri Frequent Contributor
Hi Miri,
This thread relates to a very specific issue with multiple graphics configurations...
Can you confirm that exactly the same application/data works fine on other machines and it is just this particular model which exhibits the problem?
Does this machine have a multi graphics card configuration? If so - can you try disabling first one graphics driver and running your ArcGIS Runtime app then [re]enable that driver and disable the other graphics driver and try running the application again?
Also - are you using the ArcGIS Runtime version you were given at the workshop? (as opposed to Beta 1).
Cheers
Mike
