Running GP Task of Local GP Package
2884
11-10-2011 12:59 PM
BKuiper
I'm trying to run a GP Task from a GP Package but keeping this error when i specify the input parameters:
Expected to find comma, colon or start of array; state : Empty; buffer : <html>
  <head>
    <title>ArcGISRuntime Server<
Any idea what is going wrong? is there any good code example online using ArcGIS Runtime ?
I'm trying to execute a Buffer call on a LocalFeatureLayer.
Here is a piece of my code:
                        List<GPParameter> parameters = new List<GPParameter>();
                        var uri = new Uri(this.featureLayer.Url).ToString();
                        GPFeatureRecordSetLayer param1 = new GPFeatureRecordSetLayer("parkBoundary_shp", uri);
                        parameters.Add(param1);
                        ////parameters.Add(param1);
                        gp = new Geoprocessor(task.Url);
                        gp.StatusUpdated += this.gp_StatusUpdated;
                        gp.JobCompleted += this.gp_JobCompleted;
                        gp.Failed += this.gp_Failed;
                        gp.SubmitJobAsync(parameters);
Any help is greatly appreciated! thanks!
MichaelBranscomb
Esri Frequent Contributor
The overload which accepts a Uri is expecting the Uri of a file which contains a JSON representation of the actual features themselves.
To achieve what I believe you're trying to do - you can just loop through the Graphics in the FeatureLayer and add those to a new GPFeatureRecordSetLayer e.g.
GPFeatureRecordSetLayer gpFeatureRecordSetLayer = new GPFeatureRecordSetLayer("InputFeatures");
       foreach (var g in _featureLayer.Graphics)
           gpFeatureRecordSetLayer.FeatureSet.Features.Add(g);
       parameters.Add(gpFeatureRecordSetLayer);
Or alternatively (and recommended) would be to execute a query against the FeatureLayer with the QueryTask in order to retrieve the required subset of features. The QueryTask returns a FeatureSet which contains Graphic features - so again you can easily add this to the GPFeatureRecordSetLayer parameter.
We've been working on additional samples since Beta 1 but you will find some Geoprocessing samples already in the locally installed sample application (e.g. C:\Program Files (x86)\ArcGIS SDKs\WPF10.1\SDK\Samples). At Beta 1 we shipped the whole project source code for the samples app - we've now changed this to launch as a compiled app straight from the start menu so it will be much easier to access in the forthcoming Beta 2.
Cheers
Mike
BKuiper
Got it working!
Thanks for helping us out Mike. Nice to see Esri is so closely involved with the customers.
