LineSymbol and SimpleLineSymbol not rendering without AcceleratedDisplay
10183
14
04-19-2013 10:35 AM
AaronHigh
I'm working through some performance issues with the accelerated display and have switched to working without it enabled. With the AcceleratedDisplay enabled, SimpleLineSymbols and LineSymbols both render correctly. If I turn it off, both fail to render completely. Nothing else has changed such as their geometries or symbologies. Is this a known issue and/or am I doing something wrong? Additionally, SimpleFillSymbols, PictureMarkerSymbols, and TextSymbols seem to work just fine regardless of AcceleratedDisplay settings.
Thanks.
EDIT: Code sample below
private void MakeSimpleSymbol()
            //Create a simple line symbol
            SimpleLineSymbol sls = new SimpleLineSymbol();
            sls.Color = new SolidColorBrush(Colors.Blue);
            sls.Style = SimpleLineSymbol.LineStyle.Solid;
            sls.Width = 2;
            //Create a polygon object
            Polygon p = new Polygon();
            p.SpatialReference = new SpatialReference(102100);
            //Populate it with some points
            ESRI.ArcGIS.Client.Geometry.PointCollection pointCollection = new ESRI.ArcGIS.Client.Geometry.PointCollection();
            ObservableCollection<ESRI.ArcGIS.Client.Geometry.PointCollection> rings = new ObservableCollection<ESRI.ArcGIS.Client.Geometry.PointCollection>();
            MapPoint wgsPoint = new MapPoint(0,0);
            MapPoint wgsPoint2 = new MapPoint(50,0);
            MapPoint wgsPoint3 = new MapPoint(0,50);
            pointCollection.Add(wgsPoint);
            pointCollection.Add(wgsPoint2);
            pointCollection.Add(wgsPoint3);
            rings.Add(pointCollection);
            p.Rings = rings;
            //Create a graphic and set its properties
            Graphic graphic = new Graphic();
            graphic.Geometry = p;
            graphic.Symbol = sls;
            //Create a graphics layer and add the graphic to it
            GraphicsLayer gLayer = new GraphicsLayer();
            gLayer.Graphics.Add(graphic);
            //Add the graphics layer to the map
            _map.Layers.Add(gLayer);
And in the XAML:
<Window x:Class="ESRIWPFTestApplication.MainWindow"
     xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:esri="http://schemas.esri.com/arcgis/client/2009"
        Title="MainWindow" Height="350" Width="525">
    <Grid>
        <!-- AcceleratedDisplay is OFF -->
        <esri:Map x:Name="_map" UseAcceleratedDisplay="False">
        </esri:Map>
    </Grid>
</Window>
AaronHigh
For what it's worth, an answer/workaround was posted to this question on Stack Exchange:
http://gis.stackexchange.com/questions/58598/linesymbols-not-rendering-in-arcgis-runtime-for-wpf-sdk...
Using ESRI.ArcGIS.Client.Geometry.Polyline objects instead of ESRI.ArcGIS.Client.Geometry.Polygon objects will allow the use of SimpleLineSymbols for representation in non-accelerated displays. It still seems a bit odd to me that I have to change a geometry object to continue to use a known symbology when I switch out of the Accelerated Display. Any additional input on this would be greatly appreciated.
Thanks.
DavidMartin
The Help on LineSymbol and SimpleLineSymbol say they are to draw Polyline objects. I'd therefore be tempted to shift to FillSymbol or SimpleFillSymbol, which are stated as being there to draw Polygon objects.
SimpleFillSymbol has 2 properties that take a Brush. BorderBrush and Fill. If you don't want a fill, you could set the Brush.Opacity property on the Fill Brush to zero, to make it transparent.
You're then left with all the flexibility of the Brush object to determine how your border looks.
MichaelBranscomb
Esri Frequent Contributor
It's a feature of the "accelerated" rendering engine at the core of the ArcGIS Runtime, that you can supply marker, line or fill symbols and they'll be applied to the appropriate sub geometry of your shape i.e. SimpleMarkerSymbols will be applied to the vertices of Polylines and Polygons and SimpleLineSymbols will be applied to the line segments of Polylines and Polygons. The original WPF based display does not follow the same pattern.
Ideally, you should consider the "accelerated" display as the only display. However, currently there are some items which are not supported in the runtime core display, such as KML, clusterer renderers, temporal renderers.
Cheers
Mike
AnkitaBhatia
I am using the Draw object and DrawMode.LineSegment to allow the enduser to draw a line between two points.
The end points of the line are themselves graphic symbols. So actually the user would start drawing a LineSegment by clicking on one point graphic and will click on the next graphic to denote the end of draw.
The problem I am facing is when I zoom in or Zoom out the End graphics move away from the end points of the line.
As per my understanding both the Line Segment and the Graphics should move the same amount (and thus the endpoints will coincide with the graphics).
Kindly help me resolve this issue.
To mention: I am not using accelerated display coz I need to use clustering and customized Marker Symbols.
MichaelBranscomb
Are you able to post the code which demonstrates this?
Cheers
Mike
AnkitaBhatia
The code for drawing the Line in the DrawCompleted Event is
  if (drawVertex1 && drawObject.DrawMode==DrawMode.LineSegment)
                GraphicsLayer gp = GetOrCreateGraphicsLayer("MyGraphicsLayer");
                if (this.selectedGraphic.Count == 1)
                    targetID = selectedGraphic.ElementAt(0).Attributes["NAME"].ToString();
               var pipeSymbol =new SimpleLineSymbol() { Style = SimpleLineSymbol.LineStyle.Solid, Color = Brushes.Red, Width = 2 };
                viewMap.Cursor = Cursors.Arrow;
                Graphic g = new Graphic();
                g.Attributes["GraphicId"] = GraphicsCollection.Count;
                g.Attributes["SourceID"] = sourceID; //Start graphic
                g.Attributes["TargetID"] = targetID; //EndGraphic
                g.Attributes["TYPE"] = "XX";
                g.Geometry = e.Geometry;
                g.Symbol = pipeSymbol;
                g.Geometry.SpatialReference = new SpatialReference(102100);
                GraphicsCollection.Add(g);
                drawObject.IsEnabled = false;
                drawVertex1 = false;
                return;
The Graphics at the end points are Point graphics but have control templates defined as follows:
  <esri:SimpleMarkerSymbol x:Key="StartSymbol">
            <esri:SimpleMarkerSymbol.ControlTemplate>
                <ControlTemplate>
                    <Grid>
                        <!--  Marker  -->
                        <StackPanel Orientation="Vertical">
                            <Canvas>
                                <Ellipse Width="30" Height="15" />
                                <Path Width="30"
                                      Height="15"
                                      HorizontalAlignment="Left"
                                      VerticalAlignment="Top"
                                      Data="M 435.782,256.9C 410.699,256.9 390.365,244.15 390.365,228.421C 390.365,212.693 410.699,199.942 435.782,199.942M 585.239,199.942C 610.322,199.942 630.656,212.692 630.656,228.421C 630.656,244.149 610.322,256.9 585.239,256.9M 436.489,200.001L 585.822,200.001L 585.822,257.335L 436.489,257.335L 436.489,200.001 Z "
                                      Fill="Azure"
                                      Stretch="Fill"
                                      Stroke="Black"
                                      StrokeLineJoin="Round" />
                            </Canvas>
                            <TextBlock FontSize="12"
                                       FontWeight="Bold"
                                       Foreground="Black"
                                       Text="{Binding Attributes[NAME]}" />
                        </StackPanel>
                    </Grid>
                </ControlTemplate>
            </esri:SimpleMarkerSymbol.ControlTemplate>
        </esri:SimpleMarkerSymbol>
MichaelBranscomb
Do you see the same behaviour with a regular SimpleMarkerSymbol?
AnkitaBhatia
Yes the same behavior happens even when I use a SimpleMarkerSymbol. (without any control template)
MichaelBranscomb
I believe what you're seeing is just a product of the geometry of the start/end point of the line not being exactly the same as the points? i.e. - are you performing a hit test to determine which graphic the user has clicked/selected then using that as the start and end point?
To do this you could use the FindGraphicsInHostCoordinates method on the GraphicsLayer (http://resources.arcgis.com/en/help/runtime-wpf/apiref/index.html?ESRI.ArcGIS.Client~ESRI.ArcGIS.Cli....
... Actually I see from your code the user should already have a graphic selected - therefore you could use the geometry of the point(s) the user has selected to create the line (to ensure the coordinates are coincident).
Regarding the cluster renderer - unfortunately that is not yet supported in the accelerated display mode. For custom symbols you could create them programmatically in code and use RenderTargetBitmap to render them as images then assign the image as a PictureMarkerSymbol.
Generally we also advise using a Renderer to apply symbols to all features in a layer rather than creating individual symbol instances per graphic.
Cheers
Mike
