LineSymbol and SimpleLineSymbol not rendering without AcceleratedDisplay
10233
14
04-19-2013 10:35 AM
AaronHigh
I'm working through some performance issues with the accelerated display and have switched to working without it enabled. With the AcceleratedDisplay enabled, SimpleLineSymbols and LineSymbols both render correctly. If I turn it off, both fail to render completely. Nothing else has changed such as their geometries or symbologies. Is this a known issue and/or am I doing something wrong? Additionally, SimpleFillSymbols, PictureMarkerSymbols, and TextSymbols seem to work just fine regardless of AcceleratedDisplay settings.
Thanks.
EDIT: Code sample below
private void MakeSimpleSymbol()
            //Create a simple line symbol
            SimpleLineSymbol sls = new SimpleLineSymbol();
            sls.Color = new SolidColorBrush(Colors.Blue);
            sls.Style = SimpleLineSymbol.LineStyle.Solid;
            sls.Width = 2;
            //Create a polygon object
            Polygon p = new Polygon();
            p.SpatialReference = new SpatialReference(102100);
            //Populate it with some points
            ESRI.ArcGIS.Client.Geometry.PointCollection pointCollection = new ESRI.ArcGIS.Client.Geometry.PointCollection();
            ObservableCollection<ESRI.ArcGIS.Client.Geometry.PointCollection> rings = new ObservableCollection<ESRI.ArcGIS.Client.Geometry.PointCollection>();
            MapPoint wgsPoint = new MapPoint(0,0);
            MapPoint wgsPoint2 = new MapPoint(50,0);
            MapPoint wgsPoint3 = new MapPoint(0,50);
            pointCollection.Add(wgsPoint);
            pointCollection.Add(wgsPoint2);
            pointCollection.Add(wgsPoint3);
            rings.Add(pointCollection);
            p.Rings = rings;
            //Create a graphic and set its properties
            Graphic graphic = new Graphic();
            graphic.Geometry = p;
            graphic.Symbol = sls;
            //Create a graphics layer and add the graphic to it
            GraphicsLayer gLayer = new GraphicsLayer();
            gLayer.Graphics.Add(graphic);
            //Add the graphics layer to the map
            _map.Layers.Add(gLayer);
And in the XAML:
<Window x:Class="ESRIWPFTestApplication.MainWindow"
     xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:esri="http://schemas.esri.com/arcgis/client/2009"
        Title="MainWindow" Height="350" Width="525">
    <Grid>
        <!-- AcceleratedDisplay is OFF -->
        <esri:Map x:Name="_map" UseAcceleratedDisplay="False">
        </esri:Map>
    </Grid>
</Window>
AnkitaBhatia
Hi Mike!
Strangely when I don't use the geometry returned by Draw object and create my own geometry,using the start and end point as the connected points, the line is not shown.
I drag my line from one symbol to another but the line does not appear.
AnkitaBhatia
Hi Mike!
I got this to work by explicitly calling the Complete Draw on MouseUp of the map and finding the Graphic on the clicked location.
Thanks for helping me out:)
MichaelBranscomb
Esri Frequent Contributor
That's great news, thanks for the update.
Cheers
Mike
AnkitaBhatia
Mike,
I would like to understand why a geometry drawn with the Draw object behaved differently. According to me, it would have taken the location i was clicking on and on zoom both the graphic and the endpoint of the line would have moved equally.
Thus giving me an appearance like I am getting now.
Is there an explanation I am not able to figure out?
MichaelBranscomb
I'm not aware of anything in the API that would account for this (e.g. some form of scale-dependent precision) but my initial reaction is that perhaps it's something as simple as when digitizing you're at a sufficiently small scale to make the end of the line appear coincident with the point but in reality it's 100s/1000s metres away?
Cheers
