Generating an image representation for a layer
2761
06-29-2011 01:05 PM
AndreMachado
Hello!
With ArcGIS for Silverlight I can use the ToBitmap() method from the Layer class to generate a bitmap. So I can use the result as a thumbnail for my layer. With the WPF version I don't have this method. I can use the RenderTargetBitmap class to generate an image from the Map because it inherits from the Visual base class. But I don't want to take the whole map representation... I need one for each layer. The Layer class is not a Visual, so I can't render it as an image (at least not as easily as I can with the map).
I saw that the Layer class has a Canvas property. That's a LayerCanvas that inherits from a Panel and it should work. But the problem is: it's an internal property.
So just to sum up my problem: how to generate an image representation for a layer? Not the whole map... just one layer at time...! Should I just use reflection to access this property? Are there any other solutions?
Thank you!!
Regards,
Andre
JenniferNery
We currently have this available only for Silverlight. You are right that it works on an internal property Canvas. I will forward your request to our dev lead but this is not currently supported in WPF.
