EndSaveEdits ... Graphics collection is empty after successfully adding!
2985
02-25-2014 03:01 PM
michaelrosen
I'm need to add rows that contain a FK into a primary table (wrapped by an ArcGISLocalFeatureLayer).  When I add the row into the primary table, everything indicates success in the EndSaveEdits ... but sometimes the the Graphics collection still shows empty.  Can someone offer some suggestions or insight?
            theFeatureLayer.EndSaveEdits += (s2, endEditEventArgs) =>
                // I observe that after adding a row, sometimes  endEditEventArgs.Results.AddResults is 1 but theFeatureLayer.Graphics.Count is 0.  Why is that and what can I do about it?
                System.Diagnostics.Debug.Assert(theFeatureLayer == s2); // ok, as expected.
                if (endEditEventArgs.Results.AddResults != null)
                    foreach (EditResultItem r in endEditEventArgs.Results.AddResults)
                        if (!r.Success)
                        { // no problem here...
                            theLogger.WriteLine(String.Format("EndSaveEdits skipped item due to '{0}'", r.ErrorDescription));
                            continue;
                        // Fails b/c the Graphics collection is empty.
                        Graphic gr = theFeatureLayer.Graphics.Single(g => (int)g.Attributes["OBJECTID"] == (int)r.ObjectID);
                        if (gr != null)
                        { // need to use the Graphic we just added.  If only it were available....
Cristian_Galindo
... but sometimes the the Graphics collection still shows empty.  Can someone offer some suggestions or insight?.
do you have any luck with this????
Cristian_Galindo
read this post, I know it will help you:
http://forums.arcgis.com/threads/104530-Graphics-get-lost?p=373773&posted=1#post373773
You have to be aware of the layer's lifecycle:
first the layer must be created.....
Code:
var myLayer = new ArcGISLocalFeatureLayer(); // all code required to create it then initialize it
Code:
myLayer.Initialize(); ....and wait
When it finish to initialize (myLayer.Initialized event).....
you must update it
Code:
myLayer.Update(); .....and wait again...
When it finish to update (myLayer.UpdateCompleted event)....Voila!!!! you have your Graphics!!!
