Need help in building model
1570
03-18-2014 11:12 AM
ShehabMahmoud
i have built a model and working good but it includes a tool "Select By Location" while i need to share this model with Arc SDE enabled , that tool is not supported displaying this "Tool Select Layer By Location is not licensed for use in an ArcGIS Runtime package"
if someone can help me i will be grateful
MichaelBranscomb
Esri Frequent Contributor
Unfortunately the tool 'Select Layer by Location' is currently not supported for use in the ArcGIS Runtime LocalServer. I will add it as an enhancement request for a future release.
Please can you provide more details on extactly what you would like to achieve with your model/script? There is likely to be an alternative with the currently supported tools: http://resources.arcgis.com/en/help/runtime-wpf/concepts/index.html#/Supported_geoprocessing_tools/0.... Note Python is also available for use.
Cheers
Mike
