Draw a circle on a map with a radius in meters
4703
07-17-2014 08:31 AM
BenTurner
Hello,
I am trying to draw a circle on a map using ESRI ArcGIS Runtime SDK WPF 10.2. I have found this link: Circle graphic?‌ which contains a code sample which will successfully draw a circle on the map.
However, I cannot figure out how to convert a distance in meters, into the "Radius" parameter of this code.
Are there any other "Circle" solutions? or a way to convert meters into the units that this class requires?
Michael
Tags (1)
BenTurner
Hello,
I managed to get round this issue by writing some code that worked out 360 lat/lng coordinates, of radius distance away from origin, in a set of different bearings, from 0 to 359. I then converted this set of coordinates into MapPoints.
http://pastebin.com/0G2gmK7Y
BenTurner
Hello,
