Download symbols hosted on http://static.arcgis.com/images/Symbols/
19506
09-24-2013 05:56 AM
BKuiper
is there any easy way to get the symbols that are hosted on http://static.arcgis.com/images/Symbols/ and are made available through http://developers.arcgis.com/en/javascript/samples/portal_symbols/index.html
I would like to download a zip with all these symbols.
thanks!
MichaelBranscomb
Esri Frequent Contributor
As far as I'm aware, no, because they're intended to be used as PictureMarkerSymbols via http.
However, I've attached a 7-zipped text file containing a C# array of all the URL strings which you could use as-is or iterate to download the images.
Cheers
Mike
MichaelBranscomb
Cheers
Mike
BKuiper
Thanks! i made the symbols available through my website
http://bjorn.kuiper.nu/2013/09/25/picturemarkersymbols-for-offline-use/
ArnaudFERRAND1
Both are great !
- http://developers.arcgis.com/javascript/samples/portal_symbols/index.html
- the text file containing a C# array easily translate into a json array.
Thank you all
