Calculate distance of a polyline?
2284
09-25-2011 10:44 PM
linusang
Hi, how can i calculate the distance of an arbitrary polyline?
dotMorten_esri
Esri Notable Contributor
You can either use Pythagoras on each line segment and sum them up if your coordinate system is "flat", or use Vicenty's formula on the line segments if your coordinates are spherical (ie longitude/latitude). Or lastly you could use the Geometry service: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Lengths
linusang
i'm using the WebMercator, what do you suggest? And also if i would like to get the surface distance, how can I do it?
