Bing AerialWithLabels not rendering on accelerated Layers collection
2100
7
09-17-2012 07:43 AM
AaronMorrisett
I have a bing layer working on accelerated layers, however we have noticed that the LayerStyle = AerialWithLabels will only render when it is added to the regular layer collection.  the section of code that switches the layerstyle is simple and looks like the following.
   switch (bingType)                 {                     case (BingMapType.Street):                         thisType = TileLayer.LayerType.Road;                         break;                     case (BingMapType.Satellite):                         thisType = TileLayer.LayerType.Aerial;                         break;                     case (BingMapType.Hybrid):                         thisType = TileLayer.LayerType.AerialWithLabels;                         break;                 }                                 _bingLayer = new TileLayer { LayerStyle = thisType, ServerType = ServerType.Production, Token = _config.BingKey, Visible = _baseLayerVisibility, ShowLegend = false };
By this point the _bingLayer has already been added to the acceleratedLayers collection.  Note that switching to aerial and road styles render perfectly.
Any suggestions?
Regards,
    Aaron
MichaelBranscomb
Esri Frequent Contributor
Apologies I didn't remember that it was a bug in the v1.0 release of the SDK (build 396 of the ESRI.ArcGIS.Client.* dlls). It is fixed for the next release.
Cheers
Mike
MichaelBranscomb
Unfortunately I have not been able to reproduce the problem. Here's the code I'm trying - it should be approximately similar to yours:
Code:
        TileLayer _bingLayer;
        private void BingRadioButton_Checked(object sender, RoutedEventArgs e)
            string layerTypeTag = (string)((RadioButton)sender).Tag;
            ESRI.ArcGIS.Client.Bing.TileLayer.LayerType layerType = null;
            switch (layerTypeTag)
                case ("Road"):
                    layerType = TileLayer.LayerType.Road;
                    break;
                case ("Aerial"):
                    layerType = TileLayer.LayerType.Aerial;
                    break;
                case ("AerialWithLabels"):
                    layerType = TileLayer.LayerType.AerialWithLabels;
                    break;
            if (_map.Layers["_bingLayer"] != null)
                _acceleratedDisplayLayersGroup.ChildLayers.Remove(_bingLayer);
                ID="_bingLayer",
                LayerStyle = layerType,
                Token = "<ENTER TOKEN HERE>",
                Visible = true,
                ShowLegend = false
          _acceleratedDisplayLayersGroup.ChildLayers.Add(_bingLayer);
XAML:
<Grid>
    <esri:Map x:Name="_map" UseAcceleratedDisplay="False">
        <esri:AcceleratedDisplayLayers x:Name="_acceleratedDisplayLayersGroup">
        </esri:AcceleratedDisplayLayers>
    </esri:Map>
    <StackPanel Orientation="Horizontal" HorizontalAlignment="Center">
        <RadioButton x:Name="RoadRadioButton" Checked="BingRadioButton_Checked"
                        Tag="Road" IsChecked="true" Margin="5,0,0,0"
                        GroupName="Layers" Content="Road" />
        <RadioButton x:Name="AerialRadioButton" Checked="BingRadioButton_Checked"
                        Tag="Aerial" Margin="5,0,0,0"
                        GroupName="Layers" Content="Aerial" />
        <RadioButton x:Name="AerialWithLabelsRadioButton" Checked="BingRadioButton_Checked"
                        Tag="AerialWithLabels" Margin="5,0,0,0"
                        GroupName="Layers" Content="Aerial - Labels"/>
    </StackPanel>
</Grid>
Cheers
Mike
AaronMorrisett
Thanks for the reply,
  The only difference I notice between our code is that you are removing it from the collection and re-adding it when you switch layer style.  I'll give this a shot and see if it seems to help.
Regards,
    Aaron
MichaelBranscomb
Just new'ing the layer probably won't trigger the layer initialization - to confirm you could try calling Initialize() on the layer then adding it to the map.
Cheers
Mike
AaronMorrisett
Are you using the WPF pre-release .dll's that are version 3.0.0.318 or the release version 3.0.0.396.
In the pre-release version I can get all three types of the bing map to display correctly.  However if I use the release dll's I can only get road and aerial to work.
Regards,
   Aaron
AaronMorrisett
Here is the entire section of code I am using that works if I use pre-release .dll's but not with release .dll's.
XAML:
[HTML]<Window x:Class="esritest.MainWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        Title="MainWindow" Height="350" Width="525" xmlns:esri="http://schemas.esri.com/arcgis/client/2009">
    <Grid>
        <esri:Map ZoomFactor="1.5" PanDuration="0" ZoomDuration="0" WrapAround="True"  MinimumResolution=".0000001" IsLogoVisible="False" HorizontalAlignment="Stretch"  VerticalAlignment="Stretch"  Name="map1" />
        <GroupBox HorizontalAlignment="Left" VerticalAlignment="Top">
            <Grid>
                <Rectangle Fill="White" HorizontalAlignment="Stretch" VerticalAlignment="Stretch"/>
            <StackPanel Orientation="Horizontal">
            <RadioButton Name="_radioButtonRoad" Content="Road" IsChecked="True" Checked="_radioButtonRoad_Checked" Margin="3"/>
                    <RadioButton Name="_radioButtonAerial" Content="Aerial" Checked="_radioButtonAerial_Checked"  Margin="3"/>
                    <RadioButton Name="_radioButtonAerialWithLabels" Content="Aerial With Labels" Checked="_radioButtonAerialWithLabels_Checked"  Margin="3"/>
            </StackPanel>
            </Grid>
        </GroupBox>
    </Grid>
</Window>[/HTML]
Code:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using ESRI.ArcGIS.Client.Bing;
using ESRI.ArcGIS.Client;
namespace esritest
    /// <summary>
    /// Interaction logic for MainWindow.xaml
    /// </summary>
    public partial class MainWindow : Window
        AcceleratedDisplayLayers _acceleratedDisplayLayersGroup = new AcceleratedDisplayLayers();
        public MainWindow()
            InitializeComponent();
            Loaded += new RoutedEventHandler(MainWindow_Loaded);
        bool _loaded = false;
        void MainWindow_Loaded(object sender, RoutedEventArgs e)
            map1.Layers.Add(_acceleratedDisplayLayersGroup);
            if (map1.Layers["_bingLayer"] != null)
                ID = "_bingLayer",
                LayerStyle = TileLayer.LayerType.Road,
                Token = "My Key",
                Visible = true,
                 //ShowLegend = false
            _bingLayer.Initialize();
            _loaded = true;
        private void _radioButtonRoad_Checked(object sender, RoutedEventArgs e)
            if (_loaded)
                _bingLayer = null;
                    ID = "_bingLayer",
                    Token = "My Key",
                    Visible = true,
        private void _radioButtonAerial_Checked(object sender, RoutedEventArgs e)
            if (_loaded)
                _bingLayer = null;
                    ID = "_bingLayer",
                    LayerStyle = TileLayer.LayerType.Aerial,
                    Token = "My Key",
                    Visible = true,
        private void _radioButtonAerialWithLabels_Checked(object sender, RoutedEventArgs e)
            if (_loaded)
                _bingLayer = null;
                    ID = "_bingLayer",
                    LayerStyle = TileLayer.LayerType.AerialWithLabels,
                    Token = "My Key",
                    Visible = true,
MichaelBranscomb
Cheers
Mike
AaronMorrisett
Thank you sir, I'll look for it in the next release.
Regards,
   Aaron
