LocalServer.Initialize() throws error 267 -The directory name is invalid
3627
09-18-2012 01:19 PM
VincentDolan
When I call LocalServer.Initialize(), it throws: "The directory name is invalid" (error # 267)
I've used ProcessMonitor and see the last entry before the errror occurs is
Operation: CreateFile
Path: C:\longpathtomyproject\MyProject\bin\Debug\ArcGISRuntime1.0\LocalServer64\bin
Result: PATH NOT FOUND
Detail: Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
My deploment folder has the expected structure:
ArcGISRuntime1.0
  •    Client32
  •    Client64
  •    Resources
I've tried to manually create the LocalServer64\bin folder being complained about above, with no better results.
Any suggestions?
Thanks.
VincentDolan
Mike, thanks for the response, you pointed me to the right place.
I had copied files from a deployment that had been built without ticking the "Local Server" checkbox.  Calling LocalServer.Initialize() then threw the Error 267 "The directory name is invalid".  Using a deployment built with that box checked, all is well.
MichaelBranscomb
Esri Frequent Contributor
What are you building your application as?
x86 => Will require Client32 and LocalServer32 directories within the ArcGISRuntime1.0 directory.
x64 => Will require Client64 and LocalServer64 directories within the ArcGISRuntime1.0 directory.
Any CPU => Will require Client32 & LocalServer32 OR Client64 & LocalServer64 directories within the ArcGISRuntime1.0 directory depending on the OS architecture of the machine.
But you should not be manually creating those directories - you use the Deployment Tool to build your runtime deployment with the appropriate components for your chosen architecture(s).
Cheers
Mike
VincentDolan
