Hello.
I have the map displayed when the application starts, but it is a little slow to appear.
It's not fatally slow, but it's a little slow that bothers me.
Is there any way to eliminate some of the slowness?
The map I'm using is ArcGISTopographic.
Hi and thanks for reaching out to the team. We do implement http caching in the Qt API, so on subsequent access of the same map/basemap it should speed up. There's nothing specific I can offer to speed up loading that particular basemap, but if you're concerned about your app displaying something incomplete, we do have a layerViewStateChanged signal you can connect to to show a loading screen or something similar if that would help. That way you can make sure that everything is in the active state before displaying the map.
I hope that helps.
Here is some extra info about our http caching class:
https://developers.arcgis.com/qt/cpp/api-reference/esri-arcgisruntime-networkcacheconfiguration.html
I hope that helps.
Thank you for your answer.
I'll consider it.
