Map display is slow in C++.
1634
06-11-2021 12:03 AM
Kanzakiryu
Hello.
I have the map displayed when the application starts, but it is a little slow to appear.
It's not fatally slow, but it's a little slow that bothers me.
Is there any way to eliminate some of the slowness?
The map I'm using is ArcGISTopographic.
JamesBallard1
@Kanzakiryu ,
Hi and thanks for reaching out to the team. We do implement http caching in the Qt API, so on subsequent access of the same map/basemap it should speed up. There's nothing specific I can offer to speed up loading that particular basemap, but if you're concerned about your app displaying something incomplete, we do have a layerViewStateChanged signal you can connect to to show a loading screen or something similar if that would help. That way you can make sure that everything is in the active state before displaying the map.
https://developers.arcgis.com/qt/cpp/api-reference/esri-arcgisruntime-mapquickview.html#layerViewSta...
https://developers.arcgis.com/qt/cpp/api-reference/esri-arcgisruntime-layerviewstate.html#statusFlag...
I hope that helps.
Here is some extra info about our http caching class:
https://developers.arcgis.com/qt/cpp/api-reference/esri-arcgisruntime-networkcacheconfiguration.html
JamesBallard1
@Kanzakiryu ,
I hope that helps.
Kanzakiryu
Thank you for your answer.
I'll consider it.
