IEnumerable<Layer> layers_to_export = this.ViewModel.Map.OperationalLayers.Where(I => I.Name.Equals(activeLayerName)).ToList();
foreach (var layer_to_export in layers_to_export)
if (layer_to_export.Name.EndsWith("kmz") || layer_to_export.Name.EndsWith("KMZ"))
var kml_layer = layer_to_export.Clone() as KmlLayer;
await kml_layer.LoadAsync();
KmlDocument kmlDoc = new KmlDocument();
KmlDataset kmlDataset = new KmlDataset(kmlDoc);
foreach (var node in kml_layer.Dataset.RootNodes)
kmlDoc.ChildNodes.Add(node);
When this code is run, an exception is thrown at line 22: "kmlDoc.ChildNodes.Add(node);".
Exception: Esri.ArcGISRuntime.ArcGISRuntimeException: 'Object already owned.: Already owned.'
I have found that a similar exception is thrown (from some google searching) when attempting to add a reference of an object that is already being "used" somewhere else. In this case i presume that the node being Add() to the ChildNodes of the kmlDoc is already owned by the kml_layer object, therefore it cannot be added.
I am going down the path of recreating everything in the kml from scratch via parsing the kml manually. I feel like this could be done with much less code...but i havent been able to figure it out.
Thank you.
A KML node can't belong to multiple containers such as KML folders or KML documents.
Before adding a node to a new document you have to remove it from its initial document.
Justin,
Have you tried using KmlNode.SaveAsAsync()?
Justin,
