How can I copy all KmlNodes (and children nodes) from one KmlDocument to another KmlDocument
2364
10-09-2020 03:55 PM
justinfernandes
IEnumerable<Layer> layers_to_export = this.ViewModel.Map.OperationalLayers.Where(I => I.Name.Equals(activeLayerName)).ToList();
            foreach (var layer_to_export in layers_to_export)
                if (layer_to_export.Name.EndsWith("kmz") || layer_to_export.Name.EndsWith("KMZ"))
                    var kml_layer = layer_to_export.Clone() as KmlLayer;
                    await kml_layer.LoadAsync();
                    KmlDocument kmlDoc = new KmlDocument();
                    KmlDataset kmlDataset = new KmlDataset(kmlDoc);
                    foreach (var node in kml_layer.Dataset.RootNodes)
                        kmlDoc.ChildNodes.Add(node);
When this code is run, an exception is thrown at line 22: "kmlDoc.ChildNodes.Add(node);".
Exception:  Esri.ArcGISRuntime.ArcGISRuntimeException: 'Object already owned.: Already owned.'
I have found that a similar exception is thrown (from some google searching) when attempting to add a reference of an object that is already being "used" somewhere else.  In this case i presume that the node being Add() to the ChildNodes of the kmlDoc is already owned by the kml_layer  object, therefore it cannot be added.
I am going down the path of recreating everything in the kml from scratch via parsing the kml manually. I feel like this could be done with much less code...but i havent been able to figure it out.
Thank you.
2 Solutions
DominiqueBroux
Esri Frequent Contributor
A KML node can't belong to multiple containers such as KML folders or KML documents.
Before adding a node to a new document you have to remove it from its initial document.
TonyWakim
Justin,
Have you tried using KmlNode.SaveAsAsync()?
 KmlNode.SaveAsAsync Method
DominiqueBroux
TonyWakim
Justin,
