Has anyone got this ArcGIS Server log error and know what it means?: Failed to perform Ownership-based access control and date transformation on delta database
590
01-15-2019 10:17 AM
GregHeintz
When I edit a Feature Service (line feature class) directly in ArcMap I go through the following steps:
1.)  Create Local Copy for Editing
2.)  Start editing, delete hundreds of line features, save edits, and stop editing
3.)  Synchronize Local Edits with Server
When I do these steps the following error message appears:
When I go to ArcGIS Server Manager and look at the error message it reports the following:
Has anyone experienced this error?  Is this an ArcMap or ArcGIS Server BUG for 10.6.1.  We are currently running 10.6.1 for ArcGIS Server, ArcMap, and SDE Database.
FYI - When small edits are done with the same process above, it will sometimes sync back local edits with server successfully, but not always.
Thanks!
Greg
by Anonymous User
Not applicable
Hi Greg!
Thanks for the provided information and detailed notes. Just a quick follow-up question: are you connecting as an owner to the geodatabase of the original feature class?
There is a known bug with a very similar workflow and error message, where users are unable to synchronize attachments from ArcMap through a feature service when connecting to the geodatabase with a login that is not the owner of the feature class, NIM098660, and I'm wondering if this is what we might be running into.
Vivien
MichelleMathias
Esri Community Manager
message from Greg (came through the GeoNet email):
"Thanks for responding.  This isn’t a problem for our Organization anymore."
Michelle Mathias
Manager, Community Experience & Programs
