I created the sample WPF application using ArcGIS Runtime SDK for Dot Net.
I loaded the local slpk file with one building which is exported from City Engine.
I cannot able to get that object attributes at runtime which is given in City Engine.
See below figure for what exactly I need?
How to get this object attributes in WPF app, when I click that building?
Already I referred the following link
https://developers.arcgis.com/net/wpf/sample-code/update-attributes-feature-service/
https://developers.arcgis.com/net/wpf/sample-code/scene-layer-selection/
But can not able to get the City Engine object attributes .
My code is below
ArcGISSceneLayer sceneLayer = new ArcGISSceneLayer();
foreach (var sl in MySceneView.Scene.OperationalLayers)
if (!string.IsNullOrEmpty(sl.Id))
sceneLayer = (ArcGISSceneLayer)sl;
sceneLayer.ClearSelection();
IdentifyLayerResult identifyResult = await MySceneView.IdentifyLayerAsync(sceneLayer, e.Position, 10, false, 1);
IReadOnlyList<GeoElement> geoElements = identifyResult.GeoElements;
if (geoElements.Any())
GeoElement geoElement = geoElements.FirstOrDefault();
if (geoElement != null)
sceneLayer.SelectFeature((Feature)geoElement);
var _selectedFeature = (ArcGISFeature)identifyResult.GeoElements.First();
string currentAttributeValue = _selectedFeature.Attributes["City"].ToString();
above code raise the following exception
The given key 'City' was not present in the dictionary.
Please give us advice
Thanks
Can anybody suggest the solution for this problem.
Please give us advice.
