Urgent Help Please
1060
03-07-2013 09:55 PM
raffia
Dear all coders;
I have a very weird error, a simple two layer mao is causing this weird "not registered with arcgis" error,
here is the code
#define kTiledMapServiceURL @"http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer" #define kDynamicMapServiceURL @"http://arcgis2.roktech.net/ArcGIS/rest/services/DigitalEg/CFC_En/MapServer/"
UIView<AGSLayerView>* lyr = [self.mapView addMapLayer:tiledLayer withName:@"Tiled Layer"];
//release to avoid memory leaks [tiledLayer release]; // Setting these two properties lets the map draw while still performing a zoom/pan
lyr.drawDuringPanning = YES;
lyr.drawDuringZooming = YES;
//create an instance of a dynmaic map layer
self.dynamicLayer = [[[AGSDynamicMapServiceLayer alloc] initWithURL:[NSURL URLWithString:kDynamicMapServiceURL]] autorelease];
//set visible layers
self.dynamicLayer.visibleLayers = [NSArray arrayWithObjects:[NSNumber
Thank you very much in advance.
Regards
HumzaAkhtar
Could you provide a screenshot of the error as I have never encountered any error with the name "not registered with arcgis"?
Thanks
